1999 Chrysler 300 handle replacement
BOBWM4MJT
Interior problem
1999 Chrysler 300 6 cyl Automatic 75000 miles
I want to replace the inside door handle on the drivers side.
I have the replacement part(s) and have the door panel off, but I don't know how to remove the pin on the old one nor get the pin inserted on the new one.
Sep 7, 2009 at 4:43 AM
  • 110,248 POSTS
Which pin are you refering to?
Sep 7, 2009 at 8:29 AM
BOBWM4MJT
On the back end of the door handle (the end that goes through the door psnel) there is a cavity that holds a spring that is held in place by a 1/16" dia. x 2" steel pin. It is positioned vertically and its ends go through holes in the top and bottom of the handle cavity.
However, the handle sits within a recess in the door panel which obstructs the removal of the old pin (to replace the old broken handle) and the insertion of the new pin (when the new handle is to be put in place).
Sep 7, 2009 at 8:54 AM
  • 110,248 POSTS
Are you able to get needle nose pliers in to get it or a small screwdriver?
Sep 7, 2009 at 3:08 PM
