1999 Chrysler 300 Correct coolant Orange color.
110,000 MILES • 6 CYL • FWD • AUTOMATIC
ICY360
  • 25 POSTS
If you use the green coolant when the repair manual specifies to use orange color coolant? What will happen? If it is mixed green and orange coolant?
Sep 13, 2010 at 3:34 AM
WRENCHTECH
  • 20,760 POSTS
The only thing that will happen is that you'll lose all the benefits of the orange coolant. The orange is a silicate free, 5 year coolant. The green is a regular 2 year coolant and when the orange is contaminated with green, it is considered all green at that point.
Sep 13, 2010 at 4:06 AM
ICY360
  • 25 POSTS
In any repair advise you find from an advisior you will find a Do not use Ethylene in a orange colored recommended car. Why is that? I had no idea what coolant was put in my car when it was worked on I wanted to keep my coolant that was in already. Although, Green was put in and lasted 21 days and then poured out of my radiator. I always state that my car needs orange color and I always use orange color in my car. I need to find out why the green didn't stay in the radiator and why it poured out if possible.
Sep 13, 2010 at 6:26 AM
WRENCHTECH
  • 20,760 POSTS
I assure you it had nothing to do with the type of coolant. You just need to pressure test the cooling system to locate the leak.
Sep 13, 2010 at 8:01 AM
ICY360
  • 25 POSTS
There is only one coolant listed in the repair manual and my part is only 1 yr. old and has less than 30,000 miles on it.
Sep 15, 2010 at 3:58 AM
WRENCHTECH
  • 20,760 POSTS
And your point?
Sep 15, 2010 at 4:01 AM
