1999 Chrysler 300 Coolant and Heat
15,000 MILES • 6 CYL • FWD • AUTOMATIC
MRTURNER
My car is leaking antifreeze, and is going through one bottle of antifreeze every two days. I can always tell when the antifreeze is running low, as the heat will only work when the car is accelerated. The oil appears a normal color, however there is a steady lead basically mid-center of the car. Can anyone guide me to the diagnosis?
Thanks!
Nov 23, 2008 at 9:55 AM
  • 110,248 POSTS
If it is in the center, check the water pump and radiator.
Let me know what you find.
Mar 16, 2009 at 3:43 AM
