Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
300
Safety
Airbag
1999 Chrysler 300 airbag
1999 CHRYSLER 300
19,800 MILES • V8 • FWD • AUTOMATIC
DOYLE WILSON
MEMBER
The air bag light is on, plus the horn nor cruise control no longer works
Everything else works fine
Dec 22, 2009 at 3:47 AM
DOCFIXIT
Experienced Mechanic
Hi Problem with clock spring it powers up all the faulty systems. possible break in wiring. see diagram
Hope this helps Thanks for donate
Dec 22, 2009 at 7:09 AM
DOYLE WILSON
MEMBER
Where is this part located?, and is this the the same device that controls the horn and cruise control? because all of them went out at the same time
also, thanks for the quick reply
Doyle
Dec 22, 2009 at 8:06 AM
DOCFIXIT
Need to remove steering wheel be sure and disarm airbag or it may deploy. As I stated all nonworking items powered through clockspring.
Dec 22, 2009 at 8:17 AM
DOYLE WILSON
MEMBER
Thanks and once again for the quick reponse
Doyle
Dec 23, 2009 at 5:15 AM
DOCFIXIT
Let me know what happens appreciate the feedback
Dec 27, 2009 at 11:55 PM
DOYLE WILSON
MEMBER
The clock spring was the problem just as you stated.
again thanks for the info
Doyle
Jan 4, 2010 at 12:44 PM
DOCFIXIT
Good job glad to have helped
Jan 5, 2010 at 11:54 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
