1999 Chrysler 300 After driving for a while car does not wa
CRUZ122301DEC
  • 1999 CHRYSLER 300
  • 6 CYL
  • FWD
  • 170,000 MILES
After I drive my car for 35 40 minutes it does not want to start back up after sitting about 10 minutes
it cranks over but wont start if I keep pressing the gas peddle it almost starts but doesen't if I wait 30 minutes it starts back up fine Please Help?
I have had the timing belt replaced also the fuel injectors, throttle body cleaned. Please let me know
I am stunned 3.5 v6 300m Thanks
Thursday, March 11th, 2010 AT 6:30 PM
Next time it happens don't wait for nothing, do below immediately to determine whether it's fuel or spark problem.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Thursday, March 11th, 2010 AT 6:45 PM
