Chirping/squeaking when I step on the gas pedal?
75,400 MILES • 3.5L • 2WD • AUTOMATIC
JUDESLEXUS
  • 11 POSTS
Hello, I bought the vehicle listed above in late March that chirps/squeaks when I step on the gas pedal while in drive, but not in neutral or reverse. When I let go of the gas pedal, it stops. I believe I hear the noise either in the dashboard or in the engine bay. It's especially prevalent when I don't accelerate fast and when I maintain my speed. Additionally, about half the time when I start the engine, I hear a high pitch squeal toward the end as I'm about to release the key. Also, to note, I hear a brief low-pitch rattling/grinding in the dashboard when slowing down to a stop. The rattling/grinding noise in front of the dashboard (?) lasts about 2-3 seconds.
FYI, the following components have been replaced recently:
2/18/23 done by Shift (dealer) in Whittier, CA
- Replaced power steering pressure hose
4/5 - 4/11/23 done by Shift in Oakland, CA
- Power steering pump assembly replaced
- Replaced serpentine belt
- Pulley
- Alternator
- Tensioner(?)
4/14/23 done by my preferred shop (A) due to coolant leaking:
- Water pump replaced
- Radiator replaced
- Thermostat replaced
- Coolant/antifreeze added
4/28/23 warranty service done by O'Reilly's preferred shop (B)
- power steering pump replaced
I can add a video later.
May 9, 2023 at 1:56 AM
  • 110,248 POSTS
Have you checked the serpentine belt condition and made sure it is tight? A chirping sound can come from the belt if it is dry, worn, or loose.
Next, there are other things that can cause it. Try this and let me know if the sound stops or changes. When you hear it, lightly press on the brake pedal to see if the sound changes. If it does, we need to check the brakes.
Also, pay attention to the sound to see if it changes with vehicle speed. In other words, does it speed up and slow down based on wheel speed?
If it is loud enough to record, do so and upload it for me to hear.
joe
May 9, 2023 at 1:48 PM
JUDESLEXUS
  • 11 POSTS
Hi Joe, thanks for responding. Last week I was able to gently tug the serpentine belt from the passenger wheel well. The tension seems fine to me. But later today, hopefully, I can remove the belt (never done anything like this before) and inspect it. Since the noise started after the fluid leak and after the new water pump, radiator, and thermostat were installed, I’m thinking the belt was probably contaminated with coolant. Maybe even any of the pulleys or the engine mount? I read that I can clean the pulleys with a carburetor cleaner.
As for pressing the brake pedal gently when it squeaks/chirps, the noise does not change.
As for the sound changing based on speed, it seems the sound does not change based on speed.
Attached is the video, hope you can hear it. Let me know if you need another video of it. Thanks again!
May 10, 2023 at 2:04 AM
  • 110,248 POSTS
I did hear it. That sounds like the belt. Inspect it and try cleaning things. I think you are correct about the belt being contaminated.
Let me know what you find or if there is anything I can do to help.
May 10, 2023 at 12:48 PM
JUDESLEXUS
  • 11 POSTS
Thanks Joe! I jacked the car up and took the passenger wheel off yesterday. There’s no way I could get my arm to reach up for the belt and pulleys. Too tight in there. Will have to think of another way to replace the belt and clean the pulleys. Stay tuned.
May 11, 2023 at 12:41 AM
  • 55,684 POSTS
JACOBANDNICKOLAS is one of our best please let us know what you find.
May 11, 2023 at 11:04 AM
JUDESLEXUS
  • 11 POSTS
Thanks Joe and Ken! Will be taking the car to a mechanic tomorrow. Hopefully cleaning the pulleys with carburetor cleaner and replacing the serpentine belt with OEM will do the trick... will update once the work is done.
May 15, 2023 at 1:43 AM
  • 110,248 POSTS
Thank you for the update. I understand reaching different components can be a nightmare. They don't make them easy anymore. LOL
Regardless, let us know. We are interested in knowing if the issue is resolved.
May 15, 2023 at 12:12 PM
JUDESLEXUS
  • 11 POSTS
My arms aren't even big, and I wasn't able to reach the pulleys comfortably/confidently. Anyway, the shop called to reschedule the appt for next week as their Toyota specialist is not available this week. Will update when all is done.
May 16, 2023 at 1:32 AM
JUDESLEXUS
  • 11 POSTS
Hello, I guess I’ll have to wait until the first week of June for the mechanic to look at the car.
Btw, I watched a YouTube video of a guy’s vehicle doing almost the same thing - squeaking chirping while accelerating while at HWY speeds. He later posted that his mechanic tightened the exhaust manifold bolts and that did the trick. So, I asked ChatGPT this:
ME: Can a loose bolt on an exhaust manifold or worn gasket cause the chirping squeaking noise while gently accelerating in drive?
ChatGPT:
Yes, a loose bolt on an exhaust manifold or a worn gasket can potentially cause a chirping or squeaking noise while gently accelerating in drive. When the exhaust manifold bolts are loose or the gasket is worn, it can create gaps or leaks in the exhaust system. This can lead to the emission of unusual sounds, such as chirping or squeaking, as exhaust gases escape through the gaps or interact with other components.
ME: What if I put it in neutral and step on the gas pedal? Will it make the same noise?
ChatGPT: If you put the vehicle in neutral and step on the gas pedal, and the chirping or squeaking noise persists, it can help narrow down the source of the issue. If the noise remains the same or changes in a similar manner compared to when you are in drive, it is less likely to be related to the exhaust system.
In such cases, other potential causes should be considered. Some possibilities may include issues with the engine components, such as the serpentine belt, pulleys, or accessories like the alternator or power steering pump. It could also be related to a problem with the transmission or drivetrain components.
ME: So are you saying that if the noise remains the same when in drive or in neutral while stepping on the gas pedal, that it’s probably not related to the exhaust system?
ChatGPT: Yes, if the noise remains consistent whether the vehicle is in drive or in neutral while stepping on the gas pedal, it suggests that the issue is less likely to be directly related to the exhaust system. While it's not possible to pinpoint the exact cause without a proper inspection, other components such as the engine, belts, pulleys, or transmission could be the source of the noise.
Interesting to say the least. Would you agree with ChatGPT? I’m going to research on where the exhaust manifold is located on my car and see if I can tighten the bolts up. Stay tuned.
May 18, 2023 at 1:09 PM
JUDESLEXUS
  • 11 POSTS
This morning, I took the car to another mechanic who told me the engine and transmission mounts are going bad, which is causing the squeaking upon gentle acceleration. He showed me how much the transmission and engine move when his assistant was stepping on the gas pedal. Only symptoms I'm seeing when I google worn mounts are rattling and clunking, no squeaking. Do you know if worn mounts can cause squeaking as well?
May 22, 2023 at 7:28 AM
  • 110,248 POSTS
Yes, it can. Actually, the mount itself may not make the noise, but the excessive movement could be allowing something other to make it.
Joe.
May 22, 2023 at 12:33 PM
JUDESLEXUS
  • 11 POSTS
Hello, I just wanted to give a quick update: my mech replaced the front and rear engine mounts as well as the tranny mount on the driver's side with OEM mounts that I ordered from a Lexus dealer. The result? No more squeaking!
Jun 21, 2023 at 5:13 AM
  • 110,248 POSTS
Thank you for the update. It's appreciated.
I'm glad to know the problem has been resolved. I suspect you feel the same. LOL
Feel free to come back anytime in the future if you have questions or need help. You are always welcome.
Jun 21, 2023 at 4:12 PM
JUDESLEXUS
  • 11 POSTS
Yes, it was bothering me a lot only because I was afraid it would damage other components. I didn't care much about the noise.
Just another but quick question if I may. I'm gathering opinions from pros like you... I bought the 2008 Lexus RX350 in March 2023 and it currently has 76800 miles on it. I don't think the transmission fluid has been flushed or changed yet. I heard from AMD (Car Care Nut) that if a Lexus or Toyota has over 100k miles on it, and the tranny fluid hasn't been replaced, to not replace it anymore. He didn't mention the age factor. What are your thoughts on me just doing a drain and re-fill considering its age (15 years old)? Also, any thoughts on Lucas Slip Fix? Thanks!
Jun 22, 2023 at 2:43 AM
  • 110,248 POSTS
Yes, you can do it. Once it gets extremely dirty, the theory is new fluid will cause it to slip because it cleans the clutch plates. However, that is not always the case. At this mileage, I feel you should be okay regardless of the years.
Jun 22, 2023 at 1:05 PM
JUDESLEXUS
  • 11 POSTS
Thanks Joe! Will watch videos on drain and fill.
Jun 22, 2023 at 2:14 PM
  • 110,248 POSTS
No problem. If you can start a new post, I can get you the directions. We try to keep the threads specific to one topic, so they are more helpful to others. I hope you understand.
Here is the link to start a new post:
Jun 22, 2023 at 3:49 PM
