I hear this chirping noise from the car whenever the car is in neutral. As soon as I step down on the clutch the noise seams to go away. I also hear the noise when in gear and I am traveling at low speeds (1000 rpm and less) I know some of you might say it is a throw out bearing, but I thought that was the problem when you press down on the clutch. Or could it still be that? I had the clutch replaced about a year ago. I am not sure if the throw out bearing could go bad in such a short period of time. Any help would be greatly appreciated.
Apr 13, 2017 at 6:18 AM
