Engine overheating and cooling fan not working
148,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
LARRY NASON
  • 48 POSTS
My car is overheating at idle. I do believe it is the cooling fan not turning on if you could help me out with a diagram or something of the cooling fan circuit it'd be appreciated.
Mar 25, 2022 at 10:34 AM
  • 110,248 POSTS
First, I attached the wiring schematic below for your review. I had to cut the page in half to make it readable, but I did overlap them so you can follow from one to the next.
To get started, I need you to check two fuses. Fuse 2 which is located at the battery positive terminal and fuse 9 which is in the under-hood fuse/relay box. When you check these fuses, confirm they are good and also confirm there is power to and from them. Here is a link you may find helpful:
If both fuses are good, then we need to confirm the fan relay is good. It is located in the same fuse box as fuse 9. If there is another one having the same part number, switch them to see if it makes a difference. If there isn't, here is a link explaining how to test a relay:
Try this and let me know the results.
See pics below
Note: Pic 3 shows the 60-amp fuse at the battery and pic 5 shows the fuse in the under-hood fuse box and the relay to check. I forgot to highlight the relay and can't delete pic 4, so ignore it. LOL
Mar 25, 2022 at 12:45 PM
LARRY NASON
  • 48 POSTS
Okay, I followed the steps and both fuses are good. I also swapped the relay with another like relay and still got no results.
Mar 26, 2022 at 5:40 PM
  • 110,248 POSTS
Try this: Disconnect the engine coolant temperature sensor and see if the fan runs at all times. If there is no response from the motor, try the following.
If you have power to the fuses and they are good, we next need to confirm the fan motor itself is good. Do you feel comfortable disconnecting the fan motor connector and running power directly to it to check operation?
If you do, try that and let me know the results.
Mar 27, 2022 at 6:52 AM
