My truck runs for about five minutes and shuts off and will not restart until after a few hours, then it runs about another five more minutes. I scanned an no trouble codes. It has a new fuel pump the pump has about at less 55 psi. thinking it might be the crank sensor unplug the pig wire check to the sensor and seem to be okay. wiggle the the wire a bit and plugged back in an still the same shuts off with no trouble codes. Any other options I could try? thanks.
Feb 25, 2018 at 7:28 PM
