Engine will not crank
120,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
GRIGSTWO
Battery and starter have been tested. Not getting 12v to the s terminal at the starter. Starter relay has been swapped and it does seem to work. Several engine codes all at once. P0335, P0340, P0365, P0621. What in the system could make the starting system think it’s still running and will not let it crank or what?
May 28, 2019 at 10:06 AM
  • 55,616 POSTS
The first code is for the crankshaft sensor but that will not make it not crank over. can I ask if the security light is flashing when you turn the key to the crank position? If so lets try resetting the system.
https://www.2carpros.com/articles/how-to-reset-a-security-system
This guide might help as well:
May 30, 2019 at 5:51 AM
