traction control turning on randomly
113,000 MILES • AUTOMATIC
RUBYDEEIS40
  • 7 POSTS
Hi, since I came up from Arizona to Wisconsin I have had trouble with the traction control kicking in randomly. I will be driving whether the ground is dry or has snow and ice and all of a sudden the traction control light comes on and the engine's power is cut down to like twenty or thirty mph. The suggestion in the book is to put it in L. this does not work. Then the check engine light comes on as well. The next suggestion was to click EB one click and then drive and it should shut off. However that does not work. There is no traction control button in this car to shut it off. So after it went on the other day I kept driving then all of a sudden it kicks off and I can drive it just fine. This has happened twice. Also when the traction control kicks on the speedometer does not work. And the temperature display for outside temperature does not work. If i continue to drive it and it decides to kick off the speedometer and other gauges start working too. The other day I could not get the traction control to kick off. Disconnected battery and all. As this had worked a time or two before. Anyhow I trailered it over to my cousins shop. He tested my battery with tester said it was bad. Bought a new battery. His friend was having trouble with lights on the dash coming on etc. and buying a new battery solved his cars issue. So we left with new battery. Drove thirty five miles and the traction control light came back on. Had to turn around and take it back to my cousins. Halfway there it kicked off and I was able to drive normal the rest of the way. My cousin is a little perplexed and does not understand what is going on with it. Please if anyone knows how to fix this issue I would sure appreciate it. Thank you, Sue
Jan 5, 2017 at 4:23 AM
SATURNTECH9
  • 30,868 POSTS
Your going to have to start my having the computers scanned with a professional scan tool that can read all the computers. Not a diyer scan tool and write down the exact code numbers not code descriptions you have. You might also need the scan to help diagnosis the problem your having.That is your starting point that's the first thing I would do if I had the car in front of me.
Jan 5, 2017 at 5:43 AM
STEVE W.
  • 15,420 POSTS
As Saturntech9 stated, you need a good scan tool to read the codes and live data as the problem is happening.
This issue could be a failing speed sensor that has a bad wire and triggers the problem. Or a bad ground for the body control module section that feeds the signals to the instrument panel and the DIC.
Or an issue with the body control module itself.
A dealer level tool will let you see all the modules and any codes stored there. Many of the modules will store codes that do not turn on the CEL.
Jan 5, 2017 at 7:18 PM
RUBYDEEIS40
  • 7 POSTS
Thank you .... I will tell my cousin. I know he has a lot of scan tools but not sure what kind they are. But they looked very fancy ...
Jan 5, 2017 at 11:57 PM
RUBYDEEIS40
  • 7 POSTS
I hope we can resolve the problem. I just do not have a lot of money so was trying to avoid the dealership.
Jan 5, 2017 at 11:58 PM
  • 55,770 POSTS
Hey RUBYDEEIS40,
It sounds like it could be one of your ABS wheel speed sensors is going out, Here is a guide that will help you find out which one it is.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Jan 9, 2017 at 5:07 AM
