Misfire and backfire on first start up
165,000 MILES • 7.4L
JDCHERRY
c2500, when the engine is cold RPMs jumping on initial start with misfire and slight backfire!
Feb 8, 2022 at 6:41 AM
Just to be sure this only does it on cold starting? So, when it warms up it does not have this issue?
If that is the case, then we need to jump straight to a vacuum leak.
Here is a guide that will help us get started on this:
The 454 was well known for vacuum leaks so we need to focus on this.
Next, we need to check for codes even if the check engine light is on.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let's start with this and we can go from there. There is a chance this is an actual misfire, but we need to start here.
Thanks
Feb 9, 2022 at 8:22 AM
