engine runs fine until warmed up then it backfires
85,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
RANDALL1961
engine runs fine until warmed up, about three miles, then it backfires on passenger back exhaust and slows down cannot accelerate, but will idle. I have replaced plugs cap and rotor, MAP, TPS, water temperature sending unit no positive result.
Jan 14, 2017 at 1:23 AM
HMAC300
  • 48,601 POSTS
check for a vacuum leak under TBI unit may be the problem. then scan for codes by crossing A and B b on ALDL. also, check plug wires 5000 ohms per foot.
Jan 14, 2017 at 1:42 AM
RANDALL1961
have not replaced wires. trying to avoid, but will and send you a reply as to results.
Jan 14, 2017 at 1:46 AM
  • 55,694 POSTS
Please let us know what happens so it will help others.
Best, Ken
Jan 17, 2017 at 10:17 PM
