Absolute TDC needed
200,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
FORENSICS
  • 112 POSTS
Hi, I'm getting ready to replace the intake, carburetor, and distributor on my car. I've pulled the number 1 spark plug and felt the pressure of the piston coming back up, I then used a straw to bring it to what felt like its highest point I don't think I need absolute TDC, but I just want to make sure I don't mess up the timing installing all this new stuff. The timing tab is at the top center of the balancer with a tube thing to the right. The line on the balancer is slightly passed the tab right now. I will add pictures to give a clearer idea, I just want to make sure that I have TDC to install the distributor correctly.
Thank you for reading and any help provided.
Feb 5, 2020 at 9:17 AM
FORENSICS
  • 112 POSTS
I also have a piston stop, but I've never used one and I don't know how far in the stop needs to go.
Feb 5, 2020 at 9:35 AM
Good evening,
I attached the procedure and the firing order in case you mess up the wires to the plugs.
It sounds like you are good for the top dead center.
Feb 5, 2020 at 10:22 AM
