low voltage on maf sensor
CHEVROLET VENTURE
MOMSKA70
I have a 97 chevy venture van, with about eighty thousand miles and 3.4 motor.
i recently scanned my van and found that the maf sensor has low voltage. does anyone know what this can be caused from? or maybe where to start looking for the low voltage problem.
thanks so much
Nov 1, 2007 at 3:26 PM
What's the code number?
Are you getting these symptoms: Hard to start or stall after starting. Hesitates under load, surge, idle rough or run excessively rich or lean. The engine may
also hiccup when the throttle suddenly changes position.
Nov 5, 2007 at 4:35 AM
