1998 Chevy Venture Water from Tailpipe
Suggested Repair
Have the intake manifold gasket inspected and replaced; these 3.4L engines commonly lose coolant through a failing intake gasket, which can send water out the tailpipe and cause overheating. Also consider head gaskets if white residue is in the oil fill or symptoms continue. Because the job is labor-intensive, compare shop quotes before authorizing repairs.
Conversation Summary
The owner of a 1998 Chevrolet Venture with a 3.4L reports water from the tailpipe and overheating, with no coolant in the oil or on the plugs, and asks whether a bad intake gasket is likely. The expert says varying temperature, exhaust steam, and white residue on the oil fill point to an intake gasket and possibly head gaskets. These engines are known for intake gasket failures that start with small coolant loss and worsen, and the repair is labor-intensive, so shopping around is advised.
