2004 Chevy Venture Steering Vibration and noise while drivi
2004 CHEVROLET VENTURE
110,000 MILES • 6 CYL • FWD • AUTOMATIC
2004CHEVY
While driving a roaring noise occurs. Turning steeringwheel to the right increases the noise and to the left decreases the noise. You can also feel a vibration in the steering wheel. Can you give me an idea of potential problems?
Mar 23, 2009 at 2:21 AM
  • 110,240 POSTS
Does the noise chance with speed? Does it make the noise when you are stopped? Is the power steering fluid full? Are the tires in good condition not cupped? Finally, could is sound like a bearing that is bad?
Mar 23, 2009 at 8:18 AM
2004CHEVY
Does the noise chance with speed? Yes, louder when excellerating and slowing, maintained while holding speed.
Does it make the noise when you are stopped? NO, and their is not vibration in the steering wheel while stopped
Is the power steering fluid full? Yes
Are the tires in good condition not cupped? Yes
Finally, could is sound like a bearing that is bad. My husband has checked, as this is what was recommended, but they are ok.
Mar 23, 2009 at 2:24 PM
  • 110,240 POSTS
Because it doesn't make noise when it is stopped, my recommendation is have the wheel bearings removed and checked.
Mar 24, 2009 at 12:43 AM
