2004 Chevy Venture power windows
48,000 MILES • 6 CYL • FWD • AUTOMATIC
BW6004
driver side power window went down but won't go back up. the passenger side window is fine. i don't know if it is the switch or the motor. i have limited mechanical ability.
Jan 13, 2008 at 2:12 AM
ROCKWOOD84
  • 103 POSTS
can you hear anything moving inside the door when you try the swich in the up position? if not could have blew a fuse. did the window make any weird noise before it quit? or just go down as normal then quit?could have came off track or something
Jan 27, 2008 at 8:11 PM
