The heater blows hot air all the time. I can't reduce the heat to a lower temp. The fan works fine. The a/c does not work now. It worked fine up to the time this problem occurred. My van has rear heat and air. My engine is running at normal temp on the temp gauge.
Oct 23, 2009 at 5:20 AM
