ck engine light is on again, 2 months ago I replaced the low pressure sensor & gas cap, light back on with same code P0452. W hat can I check next?
Nov 18, 2009 at 9:17 AM
✓Experienced Mechanic
A po452 is this: Evaporative Emission Control System Pressure Sensor Low Input. THe sensor most likely has a corroded wiring connection or a damaged harness. If the sensor was an aftermarket one, return it for a new one. It may be bad. THe aftermarket ones don't last.
