2003 Chevy Venture wiper motor
73,000 MILES • 6 CYL • FWD • AUTOMATIC
LADYBUG60
when I shut off my wipers, the blades are vertical and not in te usual "off" position.
I am told it could be the wiper control module.
Where is it located?
Jan 5, 2008 at 8:14 AM
VENTUREGUY
under the hood on the pasenger side you will see where the wiper linkage underneath the hood goes to a black square box monted to the firewall. Spray and soak it with any lubricant like WD-40 etc. This may loosen the pin that parks the wipers. If not while it is soak with lubricant have the wipers on low and tap the side of the square unit I mentioned above with a hammer - lightly.
This may allow the set pin to return allowing the wipers to park.
Try this before taking it to anyone that will charge you to do the same thing.
Jan 5, 2008 at 8:50 AM
