2003 Chevy Venture wheel bearing assmbely replacement
159,440 MILES • 6 CYL • FWD • AUTOMATIC
ELKARNAK
i need to know how to replace wheel bearing assmbely on front axel of venture 03 with ABS senser taking them out and put back on do you hammer them back on or need toles for that...thx
May 12, 2008 at 6:01 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
There should be a large 1 or 1 1/2 nut which keeps the drive spline, U-joint and wheel hub together. You need to remove the calipers, brake shoes, shield and rotor then you can access the hub. Remove the nut and the hub should come off the splined U-joint.
May 12, 2008 at 8:04 PM
