the turn signal on the driver side was out so i replaced it and it still wont stop flashing fast on the front and rear
Apr 9, 2010 at 5:23 AM
BLUELIGHTNIN6
✓Experienced Mechanic
check all bulbs, not just signal bulbs.
Apr 9, 2010 at 5:24 AM
GARY SKIFFINGTON
MEMBER
on both sides or just drivers side
Apr 9, 2010 at 5:30 AM
BLUELIGHTNIN6
specifically the side that flashes faster, use a tester not just visual inspection
Apr 9, 2010 at 5:31 AM
GARY SKIFFINGTON
MEMBER
what kind of tester and my van only has 159000kms not miles
Apr 9, 2010 at 5:33 AM
BLUELIGHTNIN6
just a cheap continuity tester, can pick one up for around $15 U.S. dollars
Apr 9, 2010 at 5:37 AM
GARY SKIFFINGTON
MEMBER
if i put all new bulbs in the front and rear would that repair it
Apr 9, 2010 at 5:56 AM
BLUELIGHTNIN6
would be easier just to see which is out and have a helper operate all lights while you inspect them. whichever bulb isn't working replace it. headlights, taillights, brake lights signals , all of them
Apr 9, 2010 at 6:13 AM
GARY SKIFFINGTON
MEMBER
thank you so much for this information i really appreciate it
