2003 Chevy Venture Transmission slipping when starting off
79,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIGHTWADS
  • 6 POSTS
I recently had the transmission filter and fluid changed at my local car repair shop. It is not a transmission shop. Shortly after picking up the van the transmission started to slip whenever you come to a complete stop and began to accelerate from the stop. It does not do it everytime or with any kind of pattern. It will also do it in reverse sparatically. I also have a 2003 Buick Century with 110,000 miles that this same shop serviced the transmission by changing the filter and fluid approx. 4 months ago. The car started do the exact same thing immediately after being serviced. At the time I just thought it might be because the car high miles. The transmission in both vehicles use the same tranny filter. Do you have any suggestions or have you ever heard of this happening?
Oct 24, 2008 at 1:51 PM
DENNYP
  • 1,824 POSTS
Sounds like low fluid level.
Oct 28, 2008 at 3:43 AM
TIGHTWADS
  • 6 POSTS
The fluid level is full. I checked it 1st. It tends to slip more if you have stopped and try to start off on an incline. It only slips a little then never slips again till you stop and start off too fast or on an incline. I am reaching for straws, but what would happen if the mechanic used the wrong transmission fluid?
Oct 28, 2008 at 12:42 PM
DENNYP
  • 1,824 POSTS
You might have a damaged filter seal in the transmission. You could also have one of the fluid transfer pipes in the transmission come loose. You are going to have to pull the pan and re-check the work that was done before anything else.
Oct 29, 2008 at 1:28 AM
ANWERALHUMAIDI
if you have not change your transmission fluid every 30000 miles and waited until 110000 miles. The shop shouldn't change your transmission fluid because it will start slipping and your transmission will need to replace in the near future. The preferable method dealers and shop is to drain one third of the fluid and replace it.
Mar 4, 2017 at 12:34 AM
