My chevy venture does not have interior lights. I checked all fuses and the bulbs, but no luck. What should i do next?
Dec 25, 2018 at 1:29 AM
(Merged)
HMAC300
✓Experienced Mechanic
have a pro scan for codes it may be a body module problem
(Merged)
LVZ123
MEMBER
1 POST
I am having a problem with the Interior lights. They stay on when I start the vehicle and while I am driving. They do not shut off like they did before. they use to dim off and now after 5 minutes they shut off.Could it be a door sensor?
(Merged)
DOCFIXIT
Very likely check each one manually operate switch if you get to one that does not turn off that's it. Also belive they are on timer circuit maybe faulty.
(Merged)
ANDY1995
MEMBER
1 POST
I have a 2004 chevy venture van. last night I was driving up town and my inside lights came and they did not go off so I pushed the switch to turn them off but when I flip it back off the lights still stays on"
(Merged)
HMAC300
have it scanned as it may be a body module problem also check your door switchs
(Merged)
