2003 Chevy Venture intake manifold gasket
EREZEY
Engine Cooling problem
2003 Chevy Venture 6 cyl Two Wheel Drive Automatic
What are the torqu specs for a 2003 Chevy Venture. Do you have a picture of the order inwhich they should be tightened.
Feb 20, 2010 at 2:04 AM
DAVE H
  • 13,383 POSTS
Install the lower intake manifold bolts. Tighten: Tighten the lower intake manifold bolts (1, 2, 3, 4) in sequence to 7 N.m (62 lb in) on the first pass. Tighten the lower intake manifold bolts (5, 6, 7, 8) in sequence to 13 N.m (115 lb in) on the first pass. Tighten the lower intake manifold bolts (1, 2, 3, 4) in sequence to 13 N.m (115 lb in) on the final pass. Tighten the lower intake manifold bolts (5, 6, 7, 8) in sequence to 25 N.m (18 lb ft) on the final pass.
https://images.2carpros.com/forum/automotive_pictures/266999_vent_2.jpg
Mar 12, 2010 at 12:45 AM
