2003 Chevy Venture Car won't idle anymore
75,000 MILES • 6 CYL • FWD • AUTOMATIC
KERNEL_U
  • 10 POSTS
I recently replaced my idle air control valve. When I replaced it, I cycled the engine on for 10 seconds and off for 10 seconds and then started the car. No problems. Recently I pulled the ECM fuse for 30 seconds to reset the engine codes - I plugged it back in and now the car will not idle. The engine turns over but then immediately dies. If I hold the accelerator in while starting it runs fine, but as soon as I remove my foot from the accelerator the car dies. What did I do wrong?!?
Apr 30, 2009 at 1:05 PM
  • 75,988 POSTS
The computer has to go thru a relearning process due to the computer lose its memory by removing power to it
Apr 30, 2009 at 1:16 PM
KERNEL_U
  • 10 POSTS
Got it, takes a few minutes for the computer to 'reboot' - thanks. Whew, never did that before :-)
[quote:1a64750967="rasmataz"]The computer has to go thru a relearning process due to the computer lose its memory by removing power to it[/quote:1a64750967]
Apr 30, 2009 at 1:20 PM
  • 75,988 POSTS
You learn something everyday
Apr 30, 2009 at 1:49 PM
