2003 Chevy Venture
KIDS1998
  • 5 POSTS
Other Category problem
2003 Chevy Venture 6 cyl Wheel Drive Type unknown Automatic 50,000 miles
i have a chevey venture and my fan just stoped working when i unplug the sending unit from the fan it works but when you plug it back in it don't work
Jan 17, 2008 at 5:34 AM
MASTERTECHTIM
  • 4,750 POSTS
are you talking about the radiator fan? what sending unit are you talking about? there is no sender on the fan.
Jan 17, 2008 at 5:36 AM
KIDS1998
  • 5 POSTS
yes it's the radiator fan
Jan 17, 2008 at 5:43 AM
KIDS1998
  • 5 POSTS
i think it might be a sensor and how many temp sending units are on a chevey venture 03
Jan 17, 2008 at 5:51 AM
MASTERTECHTIM
  • 4,750 POSTS
which sender did you unplug? you know the fan is only supposed to come on with the ac or the cooling system temperature reaches 228. what exactly is your problem. elaborate as much as possible. thanks
KIDS1998
  • 5 POSTS
i had no heat we fixed that prob but when my heat went out there was fluid leaking and my fan stoped working and my van started to over heat we were told to replace a sensor but that did'nt work but when you unplug the sensor my fan works when you plug it back in it starts to over heat oh the plug is up by the where you put in the thermastat
Jan 17, 2008 at 5:58 AM
MASTERTECHTIM
  • 4,750 POSTS
UNFORTUNATELY YOUR AT THE POINT WHERE YOU NEED TO HOOK UP A SCAN TOOL AND LOOK AT THE VALUES AND SEE WHAT THE COMPUTER IS READING. DOES IT OVERHEAT IF YOU LEAVE THE FAN ON?
Jan 17, 2008 at 6:02 AM
KIDS1998
  • 5 POSTS
no if the fan is on it don't over heat
Jan 17, 2008 at 6:07 AM
MASTERTECHTIM
  • 4,750 POSTS
WELL IF YOUR COOLANT TEMP SENSOR IS GOOD AND IT DOESNT OVERHEAT WITH FAN ON. IF YOUR RADIATOR CAP DOES NOT HOLD PRESSURE YOUR CAR WILL OVERHEAT AT 212 DEGREES, BEFORE THE FAN IS TRIGGERED. TRY A RADIATOR CAP. THE REASON IS WHEN YOU PRESSURIZE YOUR COOLING SYSTEM IT RAISES THE BOILING POINT 3 DEGREES FOR EVERY POUND OF PRESSURE YOU PUT ON THE SYSTEM. I HOPE THIS MAKES SENSE.
Jan 17, 2008 at 6:27 AM
