2003 Chevy Venture
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREGB27
where is the condesant drain, my van is getting my front carpets soaked when ac is on
May 29, 2008 at 3:43 PM
LEGITIMATE007
  • 5,121 POSTS
did you mean condensation? its under the dash behind the A/c switches. what probably happened is the little drain on the firewall in the engine compartment probably got clogged with debris. so the water is backing up. find the drain tube and stick a little screw driver in there and try to unclog it
May 29, 2008 at 4:12 PM
