2003 Chevy Venture
MICHELLY_NY
Heater problem
2003 Chevy Venture 6 cyl Front Wheel Drive
I ahve a 2003 Chevyy Venture Heater works fine for about 20 min. . Then it will blow cold air for les than a min. rhen it goes back to normal heat. heat gauge does not move when this happens. Could this be the thermostat?
Feb 12, 2010 at 1:45 AM
HEYOU100
  • 6 POSTS
Sounds like you could be low on coolant. Top up the coolant and check for leaks.
Apr 22, 2010 at 12:07 PM
