2002 Chevy Venture Will not start when cold
JOHNBOY22
Electrical problem
2002 Chevy Venture 4 cyl Front Wheel Drive Automatic 32k miles
I live in Florida and if the temp is below 45f the starter just clicks once,if I wait until temp is warmer starts right up. Checked terminals and connects.only hapens in cold temps.for fl anyway
Jan 28, 2008 at 11:20 PM
SERVICE WRITER
  • 9,123 POSTS
That is a 3.4 motor--6 cylinder.
Try to tap on the starter next time it happens. Ideally do it while someone has the key in the crank position.
OR check for power getting to the starter when the problem is present.
Either confirms the starter as the problem
Jan 28, 2008 at 11:26 PM
