2002 Chevy Venture Strut Torque Spec's
95,000 MILES • 6 CYL • FWD • AUTOMATIC
DMHOOT
  • 10 POSTS
Does anyone have the torque specs for the struts? Looking for the 3 upper mount nuts, center strut/spring torque, and the bottom 2 bolt/nuts. I'[m thinking ive read lower bolts around 90ftlbs, top 3 around 30ftlbs. Also, do most need alignments when struts are replaced?
May 25, 2010 at 5:18 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Your torque settings are correct, and yes you must get an alignment done after any suspension work.
mark (mhpautos)
May 25, 2010 at 7:30 PM
