2002 Chevy Venture Slow Ride
85,000 MILES • 6 CYL • FWD • AUTOMATIC
MOFCSTEWART
Car will not go past 30 or 40 mph. Someyimes it jerks too.
Sep 20, 2010 at 8:15 AM
  • 75,988 POSTS
Could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 23, 2010 at 10:59 PM
