2002 Chevy Venture RED TEMP LIGHT IS ON
49,000 MILES • 6 CYL • AWD • AUTOMATIC
ALLIE1018
THE TEMP GUAGE GOES ALL THE WAY OVER TO H.
THE HEAT BLOWS COLD AND THE RED OVERHEATING LIGHT IS COMING ON.
WHAT IS THE PROBLEM? PLEASE IF YOU CAN HELP US, WE DONT KNOW IF IT IS THE THERMOSTAT OR HEAT CORE.
THANKS
ALLIE
Dec 25, 2007 at 2:39 PM
AUTOPRO
  • 45 POSTS
first , check for coolant leak ?
Dec 25, 2007 at 3:15 PM
ALLIE1018
But ok but if there is not a leak then what?
Dec 25, 2007 at 10:16 PM
AUTOPRO
  • 45 POSTS
heater core has nothing to do with engine over heated .run the engine with rad cap opened until cooling sys circulate ( to bleed air out ) . see if the thermostat open ?
Dec 27, 2007 at 4:45 PM
