Engine Cooling problem
2002 Chevy Venture 6 cyl Front Wheel Drive Automatic
I have a coolant leak and after feeling around and a couple heat warnings on the arm and hand from the exhaust while feeling and checking hoses, I think I have spotted the location of the leak.
Looking in from the front of the van, looking under the throttle body, under the aluminum thing on the top of the engine (upper plenum?) I can see the head of a bolt and it looks like the coolant is coming from that area. (hard to tell in that small space there is to look in)
If that is where the leak is what is there that would be leaking?
red arrow pointing the direction I am looking to see water bubbling.
[img:6cdf63b96b]http://www.2carpros.com/forum/automotive_pictures/510644_image001_1.jpg[/img:6cdf63b96b]
Apr 1, 2010 at 1:42 PM
