2002 Chevy Venture compressor size
2002 CHEVROLET VENTURE
100,000 MILES • 6 CYL • FWD • AUTOMATIC
PLOOSE
Can I use a compressor from a 2002 Chevy Venture with rear A/C capability to put into my 2002 Chevy Venture that does not have rear A/C?
Aug 10, 2010 at 8:22 AM
MERLIN2021
  • 17,250 POSTS
I believe the they are different, Mitsubishi C60 is front only compressor, and Mitsubishi C69 is the dual compressor. Also the dual system takes a bit more freon... In the interest in saving money you might need the bracket from the dual compressor to make it fit, and might not, I havnt tried it, but you should get some cooling anyway Charge with 1.68 lbs of freon. Do not exceed 2.2 lbs freon(dual system charge).
Aug 10, 2010 at 8:32 AM
