2001 Chevy Venture thermostat
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
DRUTLEDGE
Where is the thermostat located and how do I remove it.
Apr 14, 2009 at 10:58 AM
F4I_GUY
  • 3,302 POSTS
Follow the rad hose on the drive side(upper). Where that hose ends, is where the thermostat is.
To remove the thermostat you must remove the exhaust heatshield and the pipe that is in the way of the thermostat housing, then remove the 2 or 3 bolts holding the housing in.
Now, I have successfully gotten the housing out with just removing the exhaust heatshield, so removal of the pipe is not necessary, although that is how the manual states to do it.
Apr 14, 2009 at 11:09 AM
