2001 Chevy Venture starter/ starter solenoid
100,000 MILES • 6 CYL • FWD • AUTOMATIC
BRADONESOURCE
where is the starter / starter solenoid located on a 2001 chevy venture van and how to replace
Dec 13, 2007 at 11:30 AM
2CARPRO JACK
  • 11,533 POSTS
side of engine closest to radiator on the bottom
Raise and support vehicle, disconnect negative battrey cable. Remove flexplate covers, remove starter solenoid and battery cables. Remove mounting bolts and shims (if it has them). Reverse procedure for install
Dec 15, 2007 at 12:12 AM
