2001 Chevy Venture oil pan....
BETOJR
Engine Mechanical problem
2001 Chevy Venture 6 cyl Two Wheel Drive Automatic
hi im trying to replace the oil pan gasket and i have removed all 12 bolts holding on to the pan and stil yet dnt budge. i also removed the brace bolt and the lower bolt found on the ac compresor... do yall have any more ideas on what it could be?
Dec 14, 2009 at 6:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
To remove oil pan, drain the engine oil.
Remove or disconnect the following:
NOTE
It is not necessary to disconnect any of the A/C lines from the compressor.
Engine mount struts
A/C compressor and set it aside
Install an engine support fixture.
Catalytic converter pipe from the right side exhaust manifold
Frame bolts and make certain that an engine stand (such as J 39580) is aligned below the engine, lower the frame
Oil level sensor wiring harness connector
Starter
Transaxle brace from the oil pan
Transaxle mount lower nuts
Engine mount lower nuts and raise the engine with the support fixture
Engine mount and bracket from the oil pan
Oil pan and gasket
Dec 18, 2009 at 11:24 AM
