2001 Chevy Venture No center console functionality
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
KCOLGAN
The center console has been acting strange. sometimes I get no A/C or heat, and the blower fan does not work. Sometimes I have to switch the fan on to high to get it started. I also noticed that my overhead center console (shows compass, out side temp, etc.) also goes blank. Noticed that the overhead center console does not light up anymore. Any help suggestions please!!!
May 25, 2010 at 4:00 AM
FREEMBA
  • 1,152 POSTS
check the following fuses in the right side fuse box (located on the side of the dash in the right front door opening):
Cluster/Batt fuse -- 10A
Ign1 fuse -- 10A
Mall/cluster fuse --10A
Pcm/PassKey/Cluster fuse -- 10A
Check to see if they are good and be sure to wiggle them to make sure that they fit snuggly into the sockets.
Jun 3, 2010 at 7:53 AM
JONMAC81
Did you ever figure your over head console out? Mine dont work either and I was wondering if you got yours fixed?
Aug 7, 2010 at 1:44 PM
BEG74
I know you asked this question about the chevy venture with no power to center console and overhead display. However, I just purchased one and I am having the same exact problem. Did you ever figure it out? If so, please respond as to what worked! Thank you so much.
May 27, 2014 at 7:16 AM
