2001 Chevy Venture Hesitating Engine
163,000 MILES • 6 CYL • FWD • AUTOMATIC
AXFRADETTE
only in the morning when van first starts, engine will not run smoothly, will hesitate and when apply pressure to gas pedal, engine will hesitate... almost seems like catalytic converter clogged .. has same symptoms but i know that is not it because when car warms up, it runs fine. already changed fuel pump.. was not the cause. have 3 error codes as follows
P1374- 3x reference circuit
P0171- fuel trim system lean (bank 1)
P0420- catalyst system low efficiency
i have done extensive research on these codes and know that either
**my o2 sensor could be dirty/damaged
**mass air flow sensor dirty
please help!!?? i read about people in exact same situation that spent $2000 to fix vehicle and was only a $100 problem at the end.
Jan 16, 2009 at 4:50 AM
  • 75,988 POSTS
Engine hesitation could be caused by the following:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jan 16, 2009 at 4:59 AM
AXFRADETTE
this could be the problem because iknow there is a misfire in one of my cylinders.. there may be a few bad plug wires... do you think this could be the root even though the car runs fine when warmed up?
Jan 16, 2009 at 5:07 AM
  • 75,988 POSTS
Dunno till you test it
Jan 16, 2009 at 5:57 AM
