2001 Chevy Venture codes/rough start
90,000 MILES • 6 CYL • FWD • AUTOMATIC
LITTLEBROTHER70
where do you find out what codes mean. Such as check engine light flashing on and off right after you start engine.
Also having problem with rough start.
Apr 12, 2008 at 4:48 AM
MERLIN2021
  • 17,250 POSTS
have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
Apr 12, 2008 at 4:49 AM
LITTLEBROTHER70
Thanks I will try to go to Autozone.
Any ideas about the rough start. It acts like an older car that we would say cold natured.
Apr 12, 2008 at 4:53 AM
MERLIN2021
  • 17,250 POSTS
Hard startying can be anything from a bad Engine coolant temp sensor, to a vacuum leak, stuck egr or bad idle air control, but hopefully the codes will point us in the right direction!
Apr 12, 2008 at 5:38 AM
