2001 Chevy Venture after overheat will not start
130,000 MILES • 6 CYL • FWD • AUTOMATIC
MOTO13088
i overheated due to a faulty radiator. i stalled now i can start the engine. it cranks fast but no start. any ideas?
Dec 27, 2009 at 12:04 AM
  • 75,988 POSTS
Do basic stuffs below might lead you somewhere if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Dec 27, 2009 at 7:29 AM
