2000 Chevy Venture Where is the RAP relay located?
STEPJAM
Electrical problem
2000 Chevy Venture 6 cyl Two Wheel Drive Automatic
I would like to locate the RAP (Retained Accessory Power) relay and/or its associated terminal block. I need to find a switched +12V source. Can I take it from this relay? Thanks!
Mar 1, 2009 at 5:32 AM
STEPJAM
Never mind, I found my own answer.
I got a switched 12V source by tapping into the fused ACC signal from the fuse block to the BCM.
Works perfectly.
Mar 2, 2009 at 11:44 PM
