2000 Chevy Venture transmission delay
138,000 MILES • 6 CYL • FWD • AUTOMATIC
JPMAHER
when i put the car in drive, it takes several minutes to
engage. I get a high pitched sound when I accelerate. I put it in third gear and eventually it runs correctly. I then switch back to drive. Would changing the fluid and filter help or do I need a new transmission
Jun 13, 2010 at 4:28 AM
FACTORYJACK
  • 4,159 POSTS
Several minutes of delayed engagement is extreme, it could mean internal seal leakage. If you have this accompanied with noise, it is probably on it's way out, it is just a matter of time before it don't move at all. What does the fluid level, and condition(color,odor) look like. If it is accelerated to noise, and operational symptoms, more than likely a fluid and filter service won't be enough.
Jun 18, 2010 at 3:40 PM
