2000 Chevy Venture RH front passenger window regulator &amp
198,982 MILES • 6 CYL • FWD • AUTOMATIC
HOMER WILLIAMS
After mounting & power raising, the regulator came loose from the motor drive gear/cam. I need to know proper mounting sequence, spring tension, & proper related timing, if needed.
Thanks
Homer
Sep 18, 2009 at 9:04 AM
MATHIASO
  • 1,209 POSTS
Do not attempt to service the regulator motor without releasing the counterbalance spring tension. The regulator lift arm is under tension from the counterbalance spring and can cause personal injury if the motor is removed from the regulator 1.Remove the door trim panel. 2.Remove the water deflector. 3.Disconnect the wiring harness from the regulator motor connector Draw a line across the spring through the center with a marker or grease pencil in order to aid in the re-installation and orientation of the counterbalance spring. Using Special , Door Module Coil Spring Tool, release the regulator spring tension, and then walk down the spring tension. Unsnap the power window motor in order to remove the power window motor from the lock module. Turn the window counter balance spring stud ¼ turn counterclockwise and remove from the module. Remove the regulator from the lock module. Gently flex the three motor retaining tabs to release the motor from the door module.
https://images.2carpros.com/forum/automotive_pictures/46384_window_motor_1.jpg
Window Switch Remove the mounting screws and pull up on the switch plate bezel. Disconnect the electrical connectors. Remove the power window switch from the bezel. Installation is the reverse order of removal hope you got everything here you need to finish the job.
Sep 18, 2009 at 12:07 PM
