2000 Chevy Venture repairs needed for safety certificate
2000 CHEVROLET VENTURE
YUMMI_MOMMI
2000 Chevy Venture 6 cyl Automatic 245112 miles
to pass a safety it needs right side lower control arm bushing, left outer tie rod end, left hub bearing, and both rear wheel cylinders, can you break down the cost of repair for me
Nov 26, 2008 at 12:55 AM
RACEFAN966
  • 5,029 POSTS
Ok here is an aprox. price on parts so you will have an idea of cost of parts if you do this yourself.
Outer tie rod-------- $58.00
Lower bushings------$18.50
Hub Assembly--------$184.00
Rear wheel cyl.------$12.99
Now keep in mind if you have a shop do this they will mark parts up so there price may be more this is based from Napa online and you doing the work.
If you have a shop do the work you will need to call them for pricing as for how much labor I can tell you labor time and you will base it from shop rates in your town. Here is how the labor breaks down now keep in mind some stuff may be combined as it takes removing some things to get to others so I will give you the rate of each individual item ok.
Lower bushing call for 1 hour
Outer tie rod calls for .9 hour
Hub assembly calls for 1.1 hours
Rear wheel cyl. calls for 1.6 hours each
Now like I said you will need get the shop rates in your town and do the math and a shop may combine some of it as it takes removing some of it to get to others. I hope this is what you were looking for and thanks
Nov 26, 2008 at 1:56 AM
YUMMI_MOMMI
thank you so much this helps alot
Nov 26, 2008 at 2:03 AM
RACEFAN966
  • 5,029 POSTS
Hey no problem we are here to help thanks for your support and enjoy your Thanksgiving.
Nov 26, 2008 at 2:25 AM
