2003 Chevrolet Venture Air Shocks
JORGE0SPERANZA
Chevy Venture, 2003, AWD, 115000 Mi, 3.4 L
Apparently this vehicle is equiped with an automatic leveling system. The rear shocks have a thin hose connected to them. It looks that these are air shocks. Is that correct?. I just bought the van and want to put new shocks. How do I know if I need to replace them or not if these are air shocks?. Lastly, if I have to replace them are there any special indications to do it?
Oct 8, 2007 at 11:42 AM
ROCKWOOD84
  • 103 POSTS
are the rear shocks leaking? does the compressor run alot? if not why replace them. if you price new ones at a dealer you' ll hope they last a long time. if the shocks don't have fluid leaking from them and are not making the compressor run alot then they are good. the auto leveling system that gm uses is exspensive to replace parts on.
Oct 27, 2007 at 5:11 PM
Suggested Repair
Inspect the rear air shocks for fluid leaks and note whether the automatic-leveling compressor runs excessively. If there is no leak and the compressor does not run often, the shocks are serviceable and do not need replacement. GM leveling-system parts are expensive, so replace them only when those symptoms are present.
Conversation Summary
The owner of a 2003 Chevrolet Venture AWD asked whether the rear shocks with thin hoses are air shocks, how to tell if they need replacement, and whether replacement requires special steps. The expert said to check for fluid leaks and frequent compressor operation; if neither is present, the shocks are good and costly parts should not be replaced unnecessarily.
