2000 Chevy Venture power windows
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOBZANY
power window switch bad. will go down but not up. its cold can hot wire switch to get window up until i can get a new one.
Jan 20, 2008 at 5:08 AM
ROCKWOOD84
  • 103 POSTS
usually the contacts get hot and burnt you can take the switch apart and scrape the contacts off so they are shiny and this will work a while.is the window doing the usual tilting down in the front as it goes up?
Jan 27, 2008 at 7:56 PM
