Power window switch bad. Will go down but not up. Its cold can hot wire switch to get window up until I can get a new one.
Sunday, January 20th, 2008 AT 1:08 PM
ROCKWOOD84
MECHANIC
Usually the contacts get hot and burnt you can take the switch apart and scrape the contacts off so they are shiny and this will work a while. Is the window doing the usual tilting down in the front as it goes up?
